;;Browser problems,Need help;;
Hello!!! :wavey: Okay well I'll start by saying that I regret deleting the browser permanently from my android, because with out it, I can not access google play to download apps which sucks :banghead: I've actually try rebooting it, :dontknow: still no luck!! :bawling: If anyone knows how to help me out, that would be great and i'll really appreciate it! 😍
Welcome to the forums Purple!!
What device do you have? You should be able to access the play store with out the browser via the PlayStore app yes?
And also, there are lot of browsers available on the Playstore.
However, if that is not possible, we can try to sideload a browser such as Maxthon browser.:) or even the PlayStore app itself.
Do you have the PlayStore app?
Very worst case scenario would be a factory reset but we need not go there quite yet:D
Hello and welcome to the community.
Here's hoping our available info onboard will be able to help you in the best way possible.
Cheers! ;)
Hey there and welcome to android forums!
I take it your rooted yes? If Mike's advice doesn't work for you, the next best option here would be getting everything backed up via titanium and doing a clean wipe.
Remember before you delete a system app, make a back up if it first fir when things like this happen :)
