Browsing Data
You don't indicate which browser or which Android version but most browsers give this option in the settings somewhere.
DSave
DSave
You're right, sorry about that omission. The phone has ICS 4.3 and I'm using the version of Chrome that came with it.
Sounds like the members above have found a solution for you. If you don't wish to use Dolphin I know that chrome removes the history when you swipe away the tabs.
So I sent an email to Dolphin and they responded with the suggestion that I try Dolphin Zero. There's a button you click when you're done browsing and then click exit. The browser deletes all the data and closes. So far a great app.
Thanx to all that responded.
