Help BT Audio only Mono?
timmywa
I did some searching here, on some other fora and google, but never saw anything definitive. I use the TuneIn Pro app and my 2012 Passat supports Bluetooth Audio and does it quite well, btw. However, when I do it with my Dinc2, the music is only mono. On my wife's iPhone 4, with the free TuneIn app, she gets full stereo BT Audio.
Does the Dinc2 support stereo BT Audio? I never found any specs either way.
Thanks.
Thanks.
Yes, it does for sure. As did my previous Inc1. I use it with bluetooth stereo headphones every day at the gym, and it's great. I also use TuneIn Pro occasionally (less now since most stations are "restricted by broadcaster").
Thanks.
I use my Inc 2 (Google Play) in my Grand Cherokee, and it works perfectly, and in stereo. Unfortunately, I could not tell how or why, I just connected it and it worked. Good luck. Maybe try just playing music through the native music player. It could be the TuneIn Pro app that's causing problems.
