Root Bugs with Iced Glacier 1.1.1?
khmergod
I've been playing with Iced Glacier all day checking out all my apps and such. It seems to work fine and smoother than stock even at stock clock. I have only one problem at the moment which never happened with stock rom. My youtube app/widget has a bug. When I use the app to watch videos, it'll loop my phone if I flip the phone to landscape and hit the back button. Once I do that my only option is to pull out the battery and turn it back on. Just was wondering if anyone else found problems with Iced Glacier rom.
if you are using the Youtube app from the market it is a known issue even with stock, there are vids all over youtube showing the MT4G going batshit crazy when using the app from the market. if you did a nandroid back up you could reload the stock ROM and pull a copy of the stock youtube .apk from it. reinstall Iced-Glacier and install your copy of the stock youtube
Thanks but did not know how to use nandroid. I did back stock rom using rom manager. Too lazy to reinstall, backup, then reinstall again lol. So far loving the OC at 1497. Very stable. When not in use I set it to 7xx/2xx. When playing games, surfing, emulators, etc, juice it up to 1500. So far no other problems other than the stupid youtube app. Too bad they don't have a GPU OC. Overclocking only helped my psx emulator just a tad. some games are still running at half speed sigh.
In a year of owning Android phones I have honestly never even tried the YouTube widget. The bug I have found is that streaming audio over Bluetooth does not work, I love the ROM though!
Does anyone on Iced Glacier have wireless tether working. My laptop will connect but I have no internet access. If there is a way to make it work please let me know as I really need this for the next couple weeks.
I have tried the built in hot spot app, wireless tether for root 2.0.2, and barnacle, non of them work since I flashed Iced Glacier. :confused:
I'm using the hot spot right know on I-G 1.1.1 haven't had any issues at all. only thing I could think of is maybe you have a corrupted download, I would try downloading again and doing a complete wipe and re-install
