Root build prop edit
slutyman
can someone edit the harmonia 2.05 build prop to get it working on metro pcs i have a rom almost fully running and all i need is to edit the build prop change cdma carrier ID and numeric to whatever Metro uses
I'm pretty sure you meant to post this on the optimus M forum....the optimus v is virgin mobile while the optimus M is metropcs, I can help you tomorrow with this....I need to sleep, school tomorrow
