Root Build.Prop Lines
michael916
I accidentaly posted this in the MetroPCS forum and idk how to delete it or have it moved so sorry for the double post. Anyway, I changed some lines in the build.prop to get the svoice thing and now my data is only working for like 5 apps. Can somebody tell me what the
ro.product.model
ro.product.name
ro.product.device
said before, i could of swore i put a back up of it on my desktop but i guess i didnt. I asked in the svoice thread but i haven't gotten an answer. I don't mean to be repetitive but i need my data to work. Thanks
Here ya go.....Also Ill go get a mod to take care of your other post for you ;)
ro.product.model=LG-MS770
ro.product.name=l0_MPCS_US
ro.product.device=l0
Heres the entire build.prop=
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IMM76I
ro.build.display.id=IMM76I
ro.build.version.incremental=MS77010c.1343313866
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=Thu Jul 26 23:44:36 KST 2012
ro.build.date.utc=1343313876
ro.build.type=user
ro.build.user=hanseog.kim
ro.build.host=LGEARND4B12
ro.build.tags=release-keys
ro.product.brand=lge
ro.product.board=L0
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=lge
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=11
ro.board.platform=msm8960
# ro.build.product is obsolete; use ro.product.device
ro.build.product=l0
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=l0_MPCS_US-user 4.0.4 IMM76I MS77010c.1343313866 release-keys
ro.build.fingerprint=lge/l0_MPCS_US/l0:4.0.4/IMM76I/MS77010c.1343313866:user/release-keys
ro.build.characteristics=default
# end build properties
# system.prop for surf
rild.libpath=/system/lib/libril-qc-qmi-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
debug.sf.hw=1
debug.egl.hw=1
debug.composition.type=dyn
ro.sf.compbypass.enable=1
# LGE_CHANGE it is given by product properties
#ro.sf.lcd_density=240
dalvik.vm.heapsize=36m
dev.pm.dyn_samplingrate=1
# system props for the cne module
persist.cne.UseCne=vendor
persist.cne.UseSwim=false
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
persist.cne.nsrm.mode=false
#ro.hdmi.enable=true
#LGE_CHANGE_S kyungmin.jun@lge.com 2011.12.19 LPA Mode off ==> 2012.02.-1 LPA Mode ON
#lpa.decode=true
lpa.decode=false
#LGE_CHANGE_E kyungmin.jun@lge.com 2011.12.19 LPA Mode off ==> 2012.02.-1 LPA Mode ON
lpa.use-stagefright=true
#system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-http=true
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.stagefright.enable-fma2dp=true
media.stagefright.enable-scan=true
# system props for the data modules
ro.use_data_netmgrd=true
#system props for time-services
persist.timed.enable=true
# System props for audio
persist.audio.fluence.mode=endfire
persist.audio.vr.enable=false
persist.audio.handset.mic=digital
# System prop to select audio resampler quality
af.resampler.quality=255
# system prop for opengles version
# 131072 is decimal for 0x20000 to report version 2
ro.opengles.version=131072
# system prop for Bluetooth Dialup Networking
# *s LGBT_COMMON_FUNCTION_DUN_DISABLE
ro.qualcomm.bluetooth.dun=false
# *e LGBT_COMMON_FUNCTION_DUN_DISABLE
# system prop for Bluetooth SAP Profile
#ro.qualcomm.bluetooth.sap=true
# LGE_CHANGE_S, 20120514, jaehun7.kim@lge.com, disable SAP
ro.qualcomm.bluetooth.sap=false
# LGE_CHANGE_E
# system prop for Bluetooth FTP profile
ro.qualcomm.bluetooth.ftp=true
# system property for Bluetooth Handsfree Profile version
ro.bluetooth.hfp.ver=1.6
#system prop for Bluetooth hci transport
ro.qualcomm.bt.hci_transport=smd
# system prop for requesting Master role in incoming Bluetooth connection.
#ro.bluetooth.request.master=true
# LGE_CHANGE_S, 20120405, byoungsun.shon@lge.com, QCT_BT_COMMON_PATCH_SR00790218
ro.bluetooth.request.master=false
# LGE_CHANGE_E
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
# system property for Bluetooth discoverability time out in seconds
# 0: Always discoverable
#debug.bt.discoverable_time=0
#system prop for switching gps driver to qmi
persist.gps.qmienabled=true
# System property for cabl
#LGE_CHANGE_S jh.chun@lge.com 2012.1.4 CABL off
ro.qualcomm.cabl=2
#LGE_CHANGE_E jh.chun@lge.com 2012.1.4 CABL off
# System prop for sending transmit power request to RIL during WiFi hotspot on/off
ro.ril.transmitpower=true
#Simulate sdcard on /data/media
# LGE_CHANGE_S
# If you use Internal-SD with FUSE, comment-out below
# 2012-01-08 warkap.seo@lge.com
#persist.fuse_sdcard=false
# LGE_CHANGE_E
ro.hwui.text_cache_width=2048
# ADDITIONAL_BUILD_PROPERTIES
ro.lge.swversion=MS77010c
ro.build.target_operator=MPCS
ro.build.target_country=US
ro.config.ringtone=01_Beyond_the_Dream.ogg
ro.com.google.clientidbase=android-lge
ro.com.google.clientidbase.ms=android-metropcs-us
ro.com.google.clientidbase.yt=android-lge
ro.com.google.clientidbase.am=android-lge
ro.com.google.clientidbase.gmm=android-lge
lgemm.player.use_android_origin=false
ro.afwdata.LGfeatureset=MPCSBASE
wifi.lge.sleeppolicy=0
wifi.lge.offdelay=true
persist.data_netmgrd_mtu=1428
persist.service.ecc.hiddenmenu=
ro.com.google.gmsversion=4.0_r3
ro.setupwizard.mode=DISABLED
ro.livewallpaper.map=DISABLED
ro.com.google.apphider=off
drm.service.enabled=true
ro.telephony.default_network=0
ro.sf.lcd_density=160
ro.hdmi.enable=false
wlan.chip.vendor=qcom
wlan.chip.version=wcnss
wifi.supplicant_scan_interval=20
wifi.lge.patch=true
persist.radio.apm_sim_not_pwdn=1
ro.cdma.home.operator.alpha=MetroPCS
ro.cdma.home.operator.numeric=311660
wifi.lge.hanglessid=true
dhcp.dlna.using=false
lpa.decode=true
keyguard.no_require_sim=true
ro.vendor.extension_library=/system/lib/libqc-opt.so
lge.signed_image=true
ro.config.notification_sound=01_Pebble.ogg
ro.config.alarm_alert=01_Alarm1.ogg
ro.lge.audio_soundexception=true
ro.lge.audio_soundprofile=true
ro.config.vc_call_vol_steps=6
ro.config.vc_call_vol_default=3
ro.lge.swversion_short=V10c
ro.lge.swversion_rev=03
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=256m
ro.lge.capp_optimusui=true
ro.lge.capp_core=true
ro.lge.capp_drm=true
ro.lge.capp_divx_drm=true
ro.lge.capp_almond=true
ro.lge.capp_bubble_popup=true
ro.lge.capp_resource=true
ro.lge.capp_wapservice=true
ro.lge.capp_osp=true
ro.lge.capp_key_light_off=true
ro.lge.capp_key_exception=true
ro.lge.capp_keyled_timeout=true
ro.lge.capp_menu_long=true
ro.lge.capp_quickclip_key=true
ro.lge.capp_touch_scroller=true
ro.lge.capp_touch_ldi=true
ro.lge.capp_mdm=true
ro.lge.capp_lockscreen=true
ro.lge.capp_valid_batteryid=true
ro.lge.fonts=true
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
