M
Member 536573
Guest
So this built in battery thing is a big deal breaker for me. No option for the extended battery which is a must w/ smartphones.
There is a hardware button sequence that simulates a battery pull. (it's hardwired into the electronics)Fwiw, it took me weeks to get used to the non-removable battery in my Galaxy Tab (7"). There were a few times that I would normally have done a battery pull.
But..a cooler head prevailed and I did get accustomed. I'm thinking that those coming from devices with replaceable batteries will adjust to the RAZR just fine. Not a huge deal, although I don't like to give up one of the attributes of Android devices that separates it from iPhones.![]()
Extended battery cases will be available, there is a hardware simulated battery pull function and the reason the batter is not removable is because of the waterproof (splash only not a pool dive) protection it had to be sealed inside.
We are all used to reboot or pulling out the battery when our phones freeze up or what not....what would we do in the case if we cant pull the battery out?
True good enough for meApparently holding the power button down for an extended period will trip the battery to off. Not a 100% option, but is what it is.
..... is it me or does the Galaxy Nexus not sexy at all?? I mean it doesnt even beat its own cousin ( Galaxy S2)... If Razr had the ICS now it would've blown Nexus out of the water but we'll have to wait for Q1 2012 for that.True good enough for me..... is it me or does the Galaxy Nexus not sexy at all?? I mean it doesnt even beat its own cousin ( Galaxy S2)... If Razr had the ICS now it would've blown Nexus out of the water but we'll have to wait for Q1 2012 for that.
IMO, the need for replaceable or extended batteries represents a design failure. The device should be able to run all day comfortably with enough battery power. You should have to have a fat phone or exchange batteries during the day.
True, I'm sure there are compatible external packs now. What I was referring to was Yodadroid hinted there would be a Moto solution. To me at least implies it may be a slightly slicker or elegant solution. Most external packs I've seen attach a phone sized dongle to the real phone, with the incidental stress those cable put on the USB port.There always are external power packs. You buy one, connectthe USB cable to it and the other end to the device - whatever device that is. It has much higher capacity than phone batteries and is much better. I have been using one from Sanyo for a few years now and find it an essential item while travelling.
I am so hoping this is unwarranted angst. Heat is absolutely the worst enemy, but seriously internal air flow isn't an issue. All these phones use a conductive cooling to the skin, then convective/radiative cooling. I have some faith that Moto has enough design genius left to solve the problem. How they could launch a major product that would simultaneously piss off the entire Bionic crowd AND be a major hardware fail just doesn't compute. Just to put this in perspective, the kevlar will be as thermally conductive as the gorilla glass.The key folks will be the heat. A batterys worst enemy is heat. IF the same 4430 as the Bionic and Droid 3, it is going to get very hot at 1.2ghz. "Water tight" also means (to some degree) air tight, so all that heat will be building in the frame where the battery is and no breathing. Seems the metal frame is probably the heat sync, but with nowhere for the heat to go but in he device- TOASTY.
That said, I'm not getting mine (if I get one) on launch day...![]()
Not long to find out. It is all in the dissipation of heat (or lack of). The weak point will still be the battery and the history of it being the main failure point for phones. No more replacing the battery and moving on, plus VZW does not have an Apple ecosystem to leverage with the Razr. Motorola prepared for this?
