secretLOVER
I just picked up the phone today and have already seen the battery complaint threads here. Does anyone bump charge? HTC is notorious for needing this.
Bump charge- when charging with power on let the battery fully charge then turn the power off and then it will FULLY charge.
You will not see an auto 10% drop after completing.
Also, if your area is experiencing outrages, this would be a battery issue as well.
It was an issue with the incredible. I got use to bump charging while getting ready for work.
EDIT: first charge happening now. will update...
EDIT #2: bump charge not needed with stock battery. Thank u for searching (bury this thread!).
