Help Burning a playlist to CD
thicks56
When I listen to music on my HTC (through the stock HTC player) if its a track that I like then I save the track to a Favourites playlist,
Is there a way to Burn the tracks from this playlist straight to a CD on my home PC or do I manually have to add each track to my burning software?
What is a CD? ;)
It depends on the software you are using. Last time I burned a CD I had to manually select the files. Maybe in the newest Nero software it can do what you are asking.
