Busybox working for Droid Explorer on PC
if you are rooted try this out.
Step 1) download busybox binary to your adb tools directory
Step 2) cd to your adb tools directory
Step 3) adb push busybox /data/local/busybox
Step 4) adb shell
Step 5) cd /data/local
Step 6) chmod 755 busybox
Step 7) ./busybox
(just to test to make sure its there)
now to have this run so droid explorer and detect your phone and so you can use busybox (ie so its in your PATH) run this.
Step 8) mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
Step 9) /data/local/busybox cp /data/local/busybox /system/bin
Step 10) mount -o ro,remount -t yaffs2 /dev/block/mtdblock3 /system
Step 11) sync
Step 12) reboot
Download Links:
Droid Explorer: Droid Explorer
busybox: Download busybox.zip from Sendspace.com - send big files the easy way
**Disclaimer- I put this together really quick so please only try if you know what you are doing so I can save my butt from any problems that may come of my or your own error** :-D
when I get to step 8 I get operation not permitted.
here's what I did.....all text copied from cmd prompt in windows 7:
care to provide some insight as to what the problem might be?
You're not root. Do a su before doing the mount thing.
type:
su
Has anybody been able to use DroidExplorer with Motorola Droid successfully? I have been able to install busyBox, but DroidExplorer does not work. I want to use the screencast app but that fails too.
Does anybody know of any other app like screencast that cud be used with Motorola Droid?
i can manipulate my directories but yes the screenshot is just black for me. not all the functionality is there yet for the droid.
Has anybody found any luck in using DroidExplorer with motorola droid in its entirety? I'd like to use Android Screencast utility, but seems like the dev on it has been halted. I'm interested in similar utilities if they are available and am ready to pay for them as well.
Just downloaded DroidExplorer, but it won't install. Seems like it is almost done, then backs out of the install and gives me an error. :confused: Tried going back to the download site, but they are currently under maintenance. O joy.
Any suggestions?
Does your machine require a proxy server to access internet?
It happened to me when i tried installing droidExplorer on a machine that uses a proxy to access internet (work computer). Installed fine on my home machine (non proxy setup).
Step 4) adb shell
Step 7) ./busybox
Step 11) sync
Step 12) reboot
Download Links:
so i get most of it but step 2 i don't please help lol i'm new to this stuff :confused:
