no bug for me, i have had it for a month now, everything works. good ? better core control, you will be able to pick different governor with buttertoast and lots of other things. i dont see anything downside in using buttertoast.
Battery life is how you set the kernel...the right settings give a great battery life with this kernel.
I'm clocked 486 min/1500something max, lagfree. My batterylife could be better. Your mileage will vary
Its dual core when needed, and single core when not. If it was dual core all the time...youre battery would be gone.
Sweep2wake, more governors. Best bet is make a nandroid, then flash it.
http://forum.xda-developers.com/showthread.php?t=1927837 be S-off, read instructions in aroma. u never mentioned what u got on ur phone. I personally have Harmonia, S-Off, twrp 1.1.1, with 0 problem with this kernel.
S-off is usually needed to flash kernel, however u might be able to use 4ext Smart Flash to flash it s-on . If that's what u wanna do mb u should wait until more people comment on this in the morning, to be more certain.
I'm S-Off and on a modified stock ROM...>.>
I dunno. Sense just appeals to me I guess. Even though themeing it is a pain in the rear at times...Everythings so baked into the framework and whatnot that one mess up renders a ROM useless at times -.-;;
When I installed Buttered Toast, I wasn't ready for the barrage of questions before the install. So I didn't bother asking about them here, I just went with it.
One particular question...on the max CPU freq. question, i chose the Qualmax standard of 1.5GHz. I thought that would be the starting max freq. but I think it's the max freq. possible period.
Kernel Tuner can't seem to OC past 1512Hz. Do I need to reinstall the kernel and choose the highest setting? BTW, it was 1.7GHz, not 1.8 or 1.9. Did I read about Buttered Toast being OC to 1.8, or was that MAC Kernel?
Also, is there a set on boot option with Kernel Tuner, or does every real time change affect the newly booted freq as well?
The Aroma settings do set things to the max OC possible. Basically it writes the kernel you want to install. If you want to OC higher than that, wipe cache and reinstall.
KT saves its settings and reapplies them on boot. Even if you flash a different kernel without wiping data, it will remember applicable settings and set them on boot.
