Anyone running Mobster HD and ButteredToast, please try something for me.
Can you take screenshots with pwr + home? What about pwr + vol down?
ALso, do you have sweep to wake enabled?
I'm running Mobster Rom HD Lite (12-29-12, not the most recent) w/Buttered Toast. No sweep to wake.
I also cannot get a screenshot using Pwr+vol or Pwr+home. The only way I can get it to work is by holding the Pwr button and then selecting Screenshot from the Power menu.
HTH,
J
How is buttered toast installed. If the answer is use Aroma, where do you get it and how is it installed? The XDA thread is for those who already know how to do it.
Brian, is Aroma contained in the same zip as is available at that link? That is, do I flash this kernel just like an updated rom using a standard recovery and the Aroma part is automatic?
Yep. Aroma installer is just a user interface that pops up automatically when you go to flash the zip through recovery. Some roms are starting to use aroma as well, so that you can customize the rom installation.
Just download the Buttered Toast zip, and flash through recovery. The installer will automatically come up and you just use the touch screen to select your options.![]()
