Hey, having issues with this danged phone. Long time reader, finally joined! So! My issue goes off of another user's on this site which was not covered-link is below. On to the problem!
'Menu, Home, Back, Search, Power, and Camera Button are not functioning correctly!
Volume Up and Down work fine.
So here is what I've tried with no luck
-trying to get to download mode but can't because buttons do not work
-attempted recovery mode, again, can't select an choice
-tried using the ButtonRemapper apk with no use, it makes all buttons useless (has a restore option, thank goodness
-tried RebootMenu apk, screen turns black -> phone needs to be reset by taking battery out**.
I thought for sure this would work!
**after taking battery out and replacing, phone boots itself up with not a single button being pressed
I am just trying to do what it takes to restore functionality. Rooted currently via OneClickRoot. Superuser and Busybox are fully updated. My guess is to try and reinstall the ROM?? Ummm, let's see...did not try installing any ROMS, bootloaders, and etc..just did the root a couple days ago and it started acting up over the past 2-3 days..driving me bonkers I swear.
Currently using the Button Savior apk when booted up which is life saver for my dead buttons; tried opening up and cleaning the hardware..to no avay....what may I have missed chaps?
Refer to this link for more info..
http://androidforums.com/admire-all-things-root/581196-problems-admire.html
There was no answer to this and it finally happened to me!
Any and all help is greatly appreciated!
ThePolak
)-tried RebootMenu apk, screen turns black -> phone needs to be reset by taking battery out**.
I thought for sure this would work!**after taking battery out and replacing, phone boots itself up with not a single button being pressed
ThePolak
