Help Buttons not responding
stick0
I'm having problem with my wildfire s, buttons don't respond after i unlock the phone from sleep mode and press the buttons it takes a while to respond after tapping 7-8 times but it works properly if the set back the phone to "factory reset" . It's really been annoying me with this problem.
Has this been happening since you bought the phone, or only more recently? If it is working fine when you perform a factory reset, it sounds like you have an app installed that is causing you some grief. Have you installed many apps so far?
Hello there I have a Wildfire S and all was well for a few weeks then when I unlocked my phone the two bottom left hand buttons took ages and about 7-8 presses to operate.
the solution to my problems was quite simple.........
Settings.....power.....uncheck fast boot.....no more probs!
Hope this helps you :)
