Root C811 M050 ipth_package.bin
What are you asking exactly, please advise so we can guide you correctly, looks like you posted in another thread asking the need for /fota/ipth_package.bin ?? We need more info so we can get your question answered. ;)
(S)he is wanting the downloaded OTA update package for the C811 for a custom ROM. The link went to a page in Korean so I'm sure the post is a poor translation.
Use gzone CA201L.
Use C811-M040 Software.
Vurizon Unlock. global USIM-SKT
Manual Update failed.
/fota/ipth_package.bin Not applicable.
Rename /mnt/external_sd/update.dat Not applivable.
I Hope Update M050
Find M050 FOTA Clean System. dd backup.
/aboot.img 512K
/boot.img 10M
/modem.img 64M
/system.img 1.25G
/rpm.img 512K
/sbl1.img 128K
/sbl2.img 256K
/sbl3.img 512K
/tz.img 512K
thank you.
Updated with the latest custom ROM links will work.
Use gzone CA201L.
I Hope Update M050
/aboot.img 512K
/boot.img 10M
/modem.img 64M
/system.img 1.25G
/rpm.img 512K
/sbl1.img 128K
/sbl2.img 256K
/sbl3.img 512K
/tz.img 512K
How do you apply this update? Copy to root of SD Card and reboot with card in place?
Do you still need the full package? I pulled the M050.mbn file from the Software Update Tool and have it saved on my hard drive. I just can't make the phone boot into recovery and apply it. It won't respond to the button combination presses.
