Root Cache to SD?
Skeletronix
I'm using apps to sd, and have been noticing my internal memory slowly dropping. If I remember correctly, this is due to apps storing their cache there. Any way to direct it to the sd card?
I don't *think* you can. Download Quick app cache cleaner from the market if you do not have it. It has a root clear all option.
In the adb shell, the command to move the Dalvik-cache to sd is:
Code:
a2sd cachesd
You'll see this and it will reboot:
Code:
a2sd cachesd
[ ] Apps2SD is launching...
[ ] Starting Darktremor Apps2SD
    Version 2.7.5 Preview Fix 4a
[ ] Starting Darktremor Apps2SD in cachesd mode
[ ] Running Apps2SD Setup Program.
[ ] Checking ext mount.
[ ] Creating Dalvik Cache on SD flag file.
[ ] Rebooting Phone.
