M
Member 324641
Guest
Used the search feature to no avail. The stock calendar app is not honoring any of my alarms/reminders setup in my Google calendar. I installed Gemini, and turned on the Notifications, but it tells me to disable any other notifications. Problem is, I can't find an option to do that anywhere.
Long story short, if anyone knows of ANY calendar app for the Fascinate that will honor alarms/reminders, please let me know. I am in desperate need of one.
TIA!
TIA!
