calendar notification sounds?
mted558
is there an app or widget that plays an alarm for an event in calendar? i'm sure it's probably right in front of me and i'm not finding it but i'm still an android noobe and have A LOT to learn.
The built-in calendar has reminders/alerts. While in the calendar, press the menu button, then -
More / Settings / Reminder settings. Pick and choose...
HTH,
-Jerry
BTW, you can also add multiple reminders to an event. So, for example, if you don't want to use the default snooze duration, you can really customize things... ;)
-Jerry
