calendar problem?
I just recently got the hero and I am having a problem with my calendar. When I go into the details of any event it always shows the prior days date (if the event is on the 6th, it will be listed in the details as the 5th even though it shows on th cal as the 6th).
Also if I set up an event as an all day event, it seems to list it as 7pm of previous day to 7pm of correct day.
Someone please help fix.
I am having the same problem with my new Droid Eris. I wonder if the issue was introduced with most recent update, since it has not been mentioned before.
Is it sychronised with a google calendar? If so, I had the same problem and it had me stumpted for a couple of minutes; login to the calendar online and check the timezone in the settings matches that of your phone.
