Help Calendar problems... won't detect google cal!!
GalaxySS
Hello everyone,
I got my Samsung galaxy captivate a month ago and I'm having some issues with the calendar (I did search everywhere for 2 days and wasn't able to fix my problem... sigh)
When I go to my calendar --> menu --> settings --> calendar, I only see "My Calendar" and I DO NOT see my xx@gmail.com address.
So, I can't see any of my google calendar tasks in my phone
When I go to my calendar --> menu --> settings --> calendar sync, I do have my default gmail account synched with contacts/gmail/calendar.
I do not have any problems with my email or anything else... it's just my calendar that is not working!!
Will factory reset solve this issue???
Do you guys see your google calendar account when you go to: calendar --> menu --> settings --> calendar
Does anyone here know how to solve this issue? Thank you so much!!:)
Indeed, you should.
Ok good, you checked the obvious. Hmm.
Kind of hard to say. I'd like to think this is just something simple missed somewhere, but nothing comes to mind. It'd suck to have to reset your phone just to fix it, but it very well might do the trick if it's worth the hassle to you.
Do you guys see your google calendar account when you go to: calendar --> menu --> settings --> calendar?
Sure do.
Indeed, you should.
Sure do.
Thanks for the reply! Do you know who I should call about this issue??
I'm using Rogers (Canada) not ATT btw.
Thanks!
