Help Calendar Problems
Hi
really getting hacked off with my SG2, using a mac.
trying to get a calendar on my macbook and phone to sync, have Ical, outlook and google calenders, pref is ical.
one will sync appts to the other, but not the other way round, have set up googlemail in ical, but only seems to sync 1 way.
am on verge of getting a filofax
can anyone suggest anything?
Hi
Here's what I use, there are two versions. iPhone & Android.
It's fast, stable, very customizable to your exact requirements.
CalenGoo Easy access to your Google Calendar with your iPhone, iPod Touch and iPad.
Introduction
I want something like that, but syncs with iCal on my macbook, have tried setting up googlemail on ical but it seems to sync only one way
