Calendar Question
JohnnyBravo1000
Android Expert
Is it possible to have events show up on my phone's calendar with different colours like you can on the calendar in Googlemail/GMail? When I try and create different calendars in the Googlemail/GMail calendar the events show up on my phone, but they don't have the same colour as the calendar on the PC.
Cheers.
I use the Jorte calendar app and it does this. There is an option in settings to use Google calendar colours.
I have to second that - Jorte is the BEST calendar app at the moment. It's even better than Pure Calendar and whatever else, as you can add directly to the calendar from the widget (and not have to deal with the stock calendar).
So, yes, it has colors. You can choose the colors, to a degree.
Tim
I'll check out Jorte. Thanks.
The colour problem was because only the bottom three rows of colours work on the Google/stock calendar. I'm not sure why this is, I assume it's a bug. If you choose a colour from above those three rows of colours then it is displayed as red by default.
