Calendar Question
Jman42028
Any idea of how to delete multiple occurances of events in the calendar at once? Or do you have to delete each one individually?
Do you use the Blur Calendar? For the Blur one, you tap the event to open it, then hit the menu. You'll see the Calendar View and Delete Event. I believe that if you hit Delete Event, it asks you if you want to delete this one occurrence or if you want to delete all occurrences.
it is using the blur calendar. However, when you click it it only deletes the one occurance. So you have to go through and manually delete each and every occurance...not good for a daily item that you no longer need.
Thanks for the reply.
Hrmm.. maybe edit the entry and turn off the repeat, then delete that one item? I am actually using LPP calendar which is a little different
