Help Calendar Reminder Snooze
jcommerce
Hello,
Does anyone know how to change the delay/snooze time on calendar reminders? (I'm not talking about the default time to remind you ahead of an event). For instance, when a reminder goes off, mine currently chimes to remind me every 5 minutes until I dismiss it. I'd like to be able to change it to 10, 15, 20, 30 minutes. Right now, if I'm in a meeting or something and I snooze it, it keeps chiming every 5 minutes and gets annoying to the point where I have to dismiss it. Then I run the risk of forgetting it.
Thanks
I am looking for a solution, and came across this:
Calendar Snooze - Android
Trying it out now, but I think it will do the trick for custom snooze times so you can get a reminder when you want it.
I prefer to have an alarm for routine events one day in advance, and then snooze it until 15 mins before the event. Can't do that on stock Evo, but I think you can do it using calendar snooze
Cool, thanks for finding that.
I agree with your last sentence...I like to do it the same way because of habit from using Outlook.
