Help Calendar - repeat/shared events not syncing
kendermouse
In the last few days, several events on my Google calendars seem to have stopped syncing with the calendar on my Epic.
It's not the whole calendars, mind you- some things (mostly once only, or once yearly things,) seem to be showing up fine, but things that repeat daily, or weekly, and several things that were added by others on the shared calendar, have stopped showing up on my phone completely.
At first, I thought it was just the widget, (I was using the calendar clock that comes already packaged,) because the actual calendar seemed to be okay, other than me having to re-add the shared calendar to the list every so often, and I switched to calwidget, after some research. But then it was having the same issues, so I checked the actual calendar again, and sure enough, there were several events missing.
Is anyone else having this problem with their Epic, or with any other android phones, and if so, have you found a workaround? It's sort of imperative that I be able to see these events from my phone.
