Help Calendar ringtone notification
harhaji
Does anyone knows how to put song in to the "ringotones" for calendar? I can not hear beeps and those stuff that are set as "ringtone" in calendar for HTC Desire HD. When I go to: Calendar - Menu -More - Setting - Reminder settings - select ringtone - all I get is some uninteresting "notifications" and I want my MP3 song to play as reminder ringtone for calnedar. Does any one knows how to solve this problem? Is there a solution??
Thanks
Apps are usually the solution to ringtone choice issues, harhaji.
I don't use them, but I believe one is called something like, "ringtone picker."
Check Market.
If you drop the MP3 you're looking to use in the notifications folder when connected to the PC, does it show up then?
I know to get the SMS notification I wanted, that's what I had to do.
