Help Calendar Settings
rfound
Member
OK, so I love having the calendar sync with google... except that for whatever reason, I can't seem to make "Google" the default calendar for creating new events on the phone. Am I missing something? I want "My Calendar" to not exist, only the google-linked calendar.
I can get events to go into the google calendar one at a time, but I can't seem to figure a way to have that be the default calendar.
It's not possible with the stock calendar app, sorry. But if you use a 3rd-party calendar app like Jorte or Gemini, they both have the option. You might want to look into them and see if one of those suits you.
If you open your calendar up hit MENU -> SETTINGS -> CALENDARS. From here you can pick and choose what calendars you want loaded on your phone. On mine it lists My Calendar [default calendar app], my Google calendar and my Facebook calendar. I only have my Google calendar checked.
When you add a new event, you can select which calendar it should go to. See the image below.
3unQxQw0OlOTmsAdsOzyL_hmlieegtb2_pR-QyLchAU
Hope that helps...
I have the problem that whenever I choose "my calendar" it duplicates ALL the facebook events, birthdays! Any idea why? When I uncheck it, it takes the birthdays away... I can't find a way for it to only show ONE birthday--it duplicates or triples!
You've got entries in both your phone's local calendar ("My Calendar") as well as your Google Calendar. So when you check both, it shows duplicated entries.
You need to decide how you want to use your calendars, and make the settings appropriately to fit that. Then you won't get duplicates.
I have un-checked "google calendar" and "facebook" so then I check only my calendar, and it still shows duplicates, some are triple entry's--
In that case, sounds like an import gone bad, like running it multiple times. Probably need to manually clean it up, or uncheck My Calendar and only use your Google calendar.
Thanks! It's weird, every program I go too, has "sync facebook" I've done everything, same thing.. oh well! I'll just deal with it, I guess! thanks!!
