Help calendar stuck
roice
Hello all,
I have Galaxy S4.
The calendar that came with it stuck (the one that synchronized with my Google account).
My supllier told me that he have to reset my mobile - thing that I realy wish to avoid (I took me lots of time to set it)
Is it possible to fix the application or reset must been done?
Thanks in advanced,
Roi.
Moved to your device forum for proper help and support, cheers
the application freeze, than I see black sreen , after 2-3 second the message: "calendar stop", and than it just to the Android main screen
I tried it without any luck....
Is it possible to fix the application without do reset to all my phone setup (like my supplier company said)?
You can download Helium from Play Store, and use it to backup your phone. Back everything up except calendar/splanner, then reformat the device. Then download Helium again and restore. This is so that you won't lose anything not related to calendar.
Thanks,
2 quistions:
1. I know that using some app can remove my phone warranty. Does Helium is one of them? Does this app hack the device?
2. Is it possible for my phone provider to uninstall my calendar and than to install it again? Is it possible at all?
Roi.
1. Nope. Removing warranty means rooting. Helium can be used without root but you need PC access.
2. Nope. The Samsung S Planner app is integrated into the system. Your carrier has nothing to do about it.
