Help calendar sync
jazztalker
Sorry if this has been solved and is common knowledge now, but I haven't really been able to keep up with the forums over the past several months. Is there any way to sync birthdates entered in the information for a contact with the calendar on your phone? I've got the full page calendar widget, but none of the birthdates I enter for any of my contacts sync over to that calendar. Is there a way to do this and/or another app I could download that would solve this?
Thanks!
Thanks!
try checking google.com/calendar settings and add it as a layer
EDIT: Settings --> Calendar settings --> Calendars ---> Check show contacts bdays
It should then pop up on your phone, if it does not try clicking menu while the calendar app is open and checking it there.
