Calendar Sync
Can anyone help me?
I installed Google Calendar sync on my PC and it syncs my Outlook calendar to my GMail calendar well.
I cannot however sync either Outlook or Gmail Calendar with my Samsung Galaxy Nexus.
When I open "Settings"-"Accounts & sync" and then go to my gmail account there are 4 Data and Synchronisation options (all of which are ticked). They are Sync Browser, Sync Contacts, Sync Gmail and Sync Google Photos....NO CALANDER OPTION!!
When I open my Claendar icon and hit the 3 dot button then "Calendars to Display" it is empty.
Can anyone help....please
Did you uninstall the calendar app?
I have 8 items under my gmail sync (i'm using google + also)
Note: the calendar sync is under gmail account
Can anyone help me?
I'm currently using Outlook 2010 with Google Calendar Sync v 0.9.4.1, I just tried making a new appointment using Outlook calendar, right click on the running Google Calendar icon and clicked on Sync. after a few seconds checked my phone, and my appointment was there. Works like a charm. Make sure the Sync Options in Google Calendar sync are configured for "2-way" and also that you set a sync time frequently (or whatever time since you can run a manual sync.)
