calender wigdet?
bword
What do you guys prefer for a calender widget? Ive tried a few havent really liked any so far. I just want a simple view of the month with stuff Ive added onto my gmail account. Ive tried the agenda one but it just displays the event not a month view. Ive tried the calender pad but the text on the month view is confusing.
Pure Grid Calendar. Hands down, the best I've used.
The calendar widget included with LauncherPro is also quite nice, but Pure Grid has many more options in terms of usage and customizability.
ill check it out thanks for recommendation...BTW do you know if you say add a event on your phones schedule will it add itself onto your gmail calender? Or does it only work one way?
No, if you want to add it to your Gmail calendar you need to specifically choose that calendar instead of "My Calendar" (the phone-only local calendar) when creating each event. You can also go back and change the target calendar of events. But you can't make your Gmail calendar the default automatically for new events. Doing that requires using a 3rd-party calendar app such as Jorte or Gemini.
i use smooth calendar widget. it displays the next three events in a rather small window so it leaves room for other icons
