call/airtime?
Hey,
Newbie here, How do I check the airtime/ call time on the nexus s?
I searched but could not find.
Thanking you in advance!
:D
Hey,
:D
Hmm, actually, I'm not sure where you might find that for the Nexus S. I know other phones have had it available in the "Device Info" section of the settings menu, but I don't see it there for the NS.
You might try opening up the dialer app and going to the Call Log tab to see if it lists anything there. My log is currently empty, so I'm not sure if it does or not.
There are also MMI codes you can use (they typically look like *#*#[SOME CODE]#*#*). I don't know of any off hand to give you call times, and they usually vary from model to model and carrier to carrier. Perhaps try ##786#.
hey,
thanks for the reply.
i checked i out before, it was *#*#4636#*#*
but i don't think the dialer option is the correct airtime
does anyone know?
