Call blocker apps question - re. known blocking international numbers
cprelude
Hi all,
Anyone know of a call-blocker app that blocks international numbers? Specifically we are within UK, and would like to know if there's an app that does this?
Paul
I use Blacklist. Which despite its name, makes an excellent white list. In other words, you can set it so that if an incoming call/text is not in your contacts it goes to voicemail or blocks the text. It logs everything so you can see the blocked call log/texts - none of which appear in your normal logs. (They will be able to leave a voicemail.)
I'm in USA and it works perfectly. Should work fine in UK also. I use the free version and you can certainly try it:
https://play.google.com/store/apps/...wsMSwyLDEsIm9yZy5iYW9sZS5hcHAuYmxhY2tsaXN0Il0.
