Help Call Blockers/Mr. Number
kamui34
Hello,
Thank you for taking the time to read my thread. I am currently in the search of an app to block calls with either forward directly to voicemail or block the number at all (no ringing or notification).
I thought the app Mr. Number would have satisified my needs (supposedly it can pickup and hang-up and forward straight to VM) but after several tries, the phone is still ringing on private/unknown and blocked number.
Could anyone recommend me another application or tell me what I am doing wrong with Mr. Number?
Thank you!
If you know the person or if the number is the same number (unlike telemarketers or bill collectors whose numbers can rotate) the phone itself has a straight to voicemail feature. I haven't actually used this feature, so I can't guarantee how well it works.
If you have the contact saved, you can click on the contact name, on the contact detail screen, press the menu hard key , select options on the screen, and check the incoming calls box.
on Sprintpcs.com or your own onlinecarriers site. you have the options to do so. I am sure it's text mesaging. so you can add the text there and its blocked.
on the phone private is private, we can dial *67 to be private. so guessing dialing back the private may not get you the number or Whatever *star. this is why private has its advantages.
we tend to just Ignore it and tellt he person online, in rder for us to answer you the next time I preferre you not make me private.
