Call Divert....
Torcrayth
Hi all
Can somebody tell me how to divert all members of a group to my O2 voicemail as being self employed and with the Christmas period on it's way I want to be able to divert work associated calls while I try to spend some quality time with my kids for a change....
Can you do this on the phone or is there an app out there that will do this for me??
All the best,
Damian
I don't have a group set up but would think it's the same principle.
Go to people App and select group/contact...scroll down to 'block caller' and activate, this will divert contact/group to voicemail...hope this helps :)
Hi Ziani.
I've tried your suggestion but all that happens to teh incoming caller is that they hear a single ring and then they get cut off....do I need to tweak a setting on my phone somewhere??
Damian
Hi Ziani.
Damian
Strange...I take it your voicemail number is correct? If so try ringing your provider for assistance....maybe someone else on here will help!
ANYONE OUT THERE PLEASE HELP......
I've now heard back from HTC and the Incredible S with Android 2.3.3 DOES NOT have a divert function!!!!!!!!!!!!!! WHY FFS!!!!
So, can anybody out there recommend an app that WILL WORK as most on Android MArket appear to have probelms with them....
