Help Call forwarding code help
Steel36
Here's what I want: when I'm at work I want Tasker to automatically forward my calls to my work phone. It can do that w/ its autodial feature.
Now, I know that *72 will forward my calls to the number I specify, and *73 will disable that once I leave the defined area.
The problem is that I use YouMail, and apparently *73 is the code for disabling the *71 busy/answer forwarding as well. It seems stupid that verizon used one code to disable 2 different features. How do I disable the *72 feature w/o disabling the *71 one?
Just got a response from YouMail saying there's nothing you can do about it.
So take note:
If you use YouMail, you can't also enjoy any call forwarding features since the *73 disable feature also screws up the YouMail message handling.
