Call Forwarding
Foxspeed
Hi all,
I just got home from abroad and since being away I have had a 'Call Forwarding' icon displayed in the notification bar that I can't get rid of. I checked the settings and it says it's disabled. How do I get rid of this icon?
BTW, I'm in the UK on 'Three' network.
Thanks.
Enable the call forwarding feature, then disable it again. If it was just stuck then that should get rid of it.
Thanks for the reply but it didn't work. There is a phone number displayed saying forward calls but don't know who's it is.
I guess I will have to get in contact with 'Three'.
EDIT:
Problem now fixed after calling 'Three'. I eventually had to type something like ##002# then press call and that gave me the option to delete the call forwarding icon.
They said it was something to do with a "network glitch".
Thanks a lot!
Just registered to say this works :)
Well that "network glitch" just happened to me as well.
Coming back from abroad just popped up on my s3's taskbar. I'm also on 3UK btw.
I have already flashed a new stable version of cyanogenmod over this morning but it was no help. I was about to reset/reinstall the whole thing when I've thought I gave it a second try on google (already googled this morning) when I came across this thread.
Typed ##002# and pressed call but nothing happened. Then after five second a msg popped up saying "deletion was successful"
So my problem solved, thanks.
