call forwarding
olabisi23
I am desperately trying to figure out how to forward my calls from my Samsung Galaxy Centura to another cell phone... Any insight? Please and Thank You!
Hi and a warm welcome to the forums! :)
Open the dial pad
Menu button
Settings
Call forwarding
The settings should be there. You need a phone network connection to change them
(Think it's the same on your phone? )
Hope this helps
Roger
Thank you kindly.
My phone when you click on settings does not give you a call forwarding option. Is there another way that you know?
Hi again
Have you opened the phone app with the dialpad showing, then press menu button and select settings? (Not menu-settings from home screen)
Roger
]Hi again
Roger[/QUOTE]
Yes Sir... i opened the call settings. It's only got options for voicemail settings. Other call settings that do not include call forwarding and internet call settings. Not sure if my phone just doesn't call forwarding. .. but if that's the case. Then that sux! 😢
Was checking that out. Got a page for sprint where they mentioned unconditional call forwarding using *72 . If you don't have the right plan, it said there was a charge of 20 cents a minute.
Might want to check into that with your carrier.
