Hi i tried in same way but some of folder in internal sd card was not removed / deleted from card. Any body know how to clear those folder.
I can't remeber the exact names, but this is where you go to wipe the internal memory.
Menu --> settings --> SDcard & Phone storage --> Unmount Internal Storage --> Format Internal Storage
This will competly wipe and reload the internal storage
Hi i tried the same way many other folder was deleted but one folder with specfic path can not deleted.
/mnt/sdcard/Android/data/com.cooliris.media
please help me to clear this folder from sd card.
Thanks
That folder /sdcard/Android is a data folder for programs running on your sdcard. If I remember correctly com.cooliris.media is the data for the gallary app; since the gallery stores its data on the internal sdcard, even if you delete it, it will come back. To make it empty; REMOVE your external sdcard and (do not put on in); reformat the internal card, factory reset the phone and then do an internal reformat again. As long as you do not put any pictures, that folder should stay empty. Because it is the gallery, if you delete it, it will just come back and fill up again.
Hi i m trying to download pdf file in my captivate. But it have given an error message" download unsuccessful. Cannot download. The content is not supported in this phone."
