Call log
rabben
Member
Hi everyone. I have recently gotten a problem with the call log! I used to have all communications in this; mostly calls and sms, but the last few days the sms is gone, only calls are showing! In settings I have checked "all logs", but still...! Anyone who can help me?
Please anyone? Anyone with similar problem? In stock call log I have lost overview of sms, only calls are showing! Used to have all communications in there!
Never had that problem so can't say if this will work but its an idea. Go into manage applications in your settings and clear dialer data. It will wipe all your call logs but when you get new messages maybe they will appear.
Are you now using Hancent or GO SMS to send/receive SMS
I found neither of these updated the call logs, and is why I'm still using the stock app.
Im using handcent sms, but has since I started using the phone! Stock sms program still receives sms. All I did was turning off notification in stock program! I could see sms in call log 2-3 weeks, but suddenly they stopped appearing! Now only calls show up! In settings, if I choose to show only sent or received sms, all appear, even the fresh ones. When I check "all logs" only calls appear:mad:. I found it really handy that everything was there!
I could never get Hancent or GO SMS to appear here. It must be something to do with the stock app notification settings.
I've even emailed both Hancent and GO SMS a few weeks back regarding this but have not had a reply off either. I've kept both apps on the phone to keep tabs on their updates, but this problem hasnt been included in any fixes as yet.
I'd be interested if you find a solution to this......
slightly to the opposite of this topic, is there anyway to have calls only?
i havent found a way to change this and its really annoying when i use my phone for business too that i dont want to be scrolling passed dozens of sms logs to get to calls i am looking for.
You can filter it to show either incoming/outgoing/missed/rejected calls, but not to all types of calls full stop
