Help Call Logs/History
bjtcars
Was playing around with the phone the other day and accidently came across the total call history in time spent on the phone,incoming and outgoing. I cannot find out how to get back there, does anybody know?
Thanks in advance.
Go to Contacts, and slide to the right. It's also available as an application called Call History.
I don't think their talking about "call history" as in the list of calls but the TOTAL time used. i.e. "outgoing calls: 129 minutes"
edit: I've seen it but I can't seem to find it now :(
Yes your right the total time. Its really bugging me that I cant find it again.
Dial ##7764726
Hit Call
Type Password is 000000
Hit Feature Settings
It should be in there. I'm not sure you can get to there some other way if your phone is not rooted.
*You have to disable "call confirm" if you use that app.
Dial ##7764726
Hit Call
Thats where I found it thanks for the help.
