Not all call recordings apps would work with Samsung Galaxy S3. Call recorders are very hardware-dependent: some would work with certain hardware, many would not. The one I'd been using on my previous phone does not work properly on S3. I have not found any call recording apps that score 4 or over out of 5 for user reviews, (and I generally avoid apps that get less than 4 out of 5 at Google Play.)
Are you rooted?
Are you rooted?
Yes, my S3 is rooted.
How much was CallRecorder when you bought it?I personally use:
https://play.google.com/store/apps/...sMSwyLDEsImNvbS5za3ZhbGV4LmNhbGxyZWNvcmRlciJd
But its very expensive now - It was cheaper when I bought it.
I use total recall. Its not free but emails all calls to you.
(Good if it gets stolen)
