palladium90
Please read the description of the program!
( The application for recording telephone conversations )
✔ Enable or disable the automatic call recording .
✔ Ability to manually record ( button while talking ) (PRO)
✔ Ability to add notes to the accounts (PRO)
✔ New photos of contacts (PRO)
✔ Password to log into the application (PRO)
✔ Search for recorded calls
✔ Hide audio files (PRO)
✔ NO ADS !
✔ Play one-touch recording (PRO)
✔ The choice of one of three formats, the output file
✔ Call Filter (white and black lists)
✔ Auto- reboot
✔ Choice of storage of records
✔ Changing the language
✔ Select the recording source (microphone, voice of the caller , the caller's voice , both channels )
✔ Play audio player
III. Running the program :
✔ Before you install, close other programs to record telephone conversations.
✔ Before installing the full version , be sure to remove the free version.
✔ If you have any problems with the recording , try to record the call from another source.
✔ If you do not record or write badly, try different combinations of the recording (for different phones optimal settings are different)
✔ By default, all calls are saved in the folder CALL_RECORDS on the SD card of your phone.
✔ If an error occurs , try the following:
1) Reset phone
2 ) Remove the program and reinstall
3) Remove the application data (Settings - > Applications -> * right * app -> delete data )
✔ Turn on / off the record (the button in the upper left corner)
✔ NO ADS !
✔ Auto- reboot
✔ Play audio player
1) Reset phone
