Help Call sound is too low.
LimonKay
Hello, apologies if wrong forum.
My Samsung Galaxy S4 recently stopped giving out its maximum sound during calls. The other party can hear me quite fine but from my end, I can hear from what it feels like only 10% of the volume.
I do raise the volume to 100% during the call but to no avail.
Here are a couple things I've noticed:
- The volume works as normal for music.
- The volume works as normal when placed on speakerphone; the issue is only while having handset on instead of speaker.
- Safe Mode did not help.
Here are following volume settings:
http://i.imgur.com/JuJUHLJ.png
http://i.imgur.com/hdg6ByI.png
I do have T-Mobile's insurance plan and I am willing to try a factory reset but those two are only last resorts to me.
Any help or advice from tech gurus would be greatly appreciated.
Mine is doing the same thing, and only began within the last week or so. The volume went from having to be turned all the way down for phone calls, to going all the way up and I still can't hear the person on the other end very well. Not even with the loudspeaker.
The only difference between my phone and yours is that mine is rooted with CyanogenMod 11 (Android 4.4.4) on it. I haven't updated the ROM in several weeks so I'm not sure what is causing the problem.
I'm with Straight Talk using AT&T towers.
Here's a screenie;
Tasker has a variable "in-call volume" referred to as %VOLC
It adjusts the volume during phone calls.
I presume it is an Android variable which is not available in the phone settings menu, only accessible through apps (like Tasker). Some other app may have changed that variable on you. Try Tasker to increase the volue of %VOLC. Mine is currently set to 5 and volume is fine for me.
Hello,
thank you both for the reply.
@Petrah,
I believe it's some app on our phones that may have recently updated and is causing the issue. Although, I'm fairly certain Safe Mode disables all apps and restores phone settings to default (correct me if I'm wrong).
Do you know if there's any way to check which apps on our phone recently updated?
@electricpete,
I purchased the Tasker app for $2.99 and checked the volume for in-calls, it is set to the maximum of 5.
Problem still lingering, any feedback would be greatly appreciated.
I paid for the Tasker app a long time ago, but unfortunately everything about the app is way over my head. I redownloaded it and could not find anything that said "variable".
I live with a programmer (it's his job) and when I watch him type up all that code is just makes my head numb lol.
@electricpete,
Ouch, I really thought that would work. Sorry you ended up spending money and time on that with no result. On the bright side, maybe you will find tasker useful for other things. I can't think of anything else to try for the in-call volume problem, sorry.
Make sure you have VoLTE turned off.
Also while making a phone call there's an option to enhance and boost the sound. The options icon is located in the picture area of the person your calling.
If you cant find the option let me know and I'll get a screen shot posted.
