Swainsmith82
Android Expert
********FOR CM10 ONLY!!!! *******
I pm'd johnnyl1111 and Xt51 and asked them to test xloud+clear audio for me and it got everything working but with the snd_soc_msm files on PG'S build or the one from my previous thread installed it is too too loud, so you'll need these files to make it all work properly.
Extract this folder and copy over existing system /etc /snd_soc_msm set permissions to rwxr xr x with the two files inside set to rw-r-r if someone wants to make a flashable for me that would be awesome. These are the two files originally in bobz 5/21 so if you have bobz 5/21 and haven't messed with this folder skip this part.
Snd_soc_msm files-
http://db.tt/ch1dpCwI
Then flash xloud+clear audio and you're all g double o d good.. Enjoy!!
Xloud+clear audio-
http://db.tt/sBxv3elv
Who would of thought?
Addition:Flashable zip provided by johnnyl1111 for files above
Snd_soc_msm flashable-
soundfix.zip
YOU NO LONGER NEED TO FLASH THE ENTIRE CLEAR AUDIO FILE UNLESS YOU WANT IT(I do so I'm keeping it up)...
Here is the only file needed from xloud+clear audio to fix in call volume sifted through and found by johnnyl1111
Single audio file flashable-
http://androidforums.com/motion-4g-all-things-root/752214-call-volume-fix.html#post6067233
Snd_soc_msm files-
Xloud+clear audio-
soundfix.zip
