call waiting question
snowcrash
Member
I know this is a basic one...but is there anyway to answer a call waiting...hang up on it and go back to the original call. There is a switch button, but it annoyingly leaves both calls open. I know if you hang up on the second call, it will make a ringing sounds for the first caller and then eventually connect you. That is not the best way of doing it...is there a better way?
