Help call waiting?
diaper84
Just realized i dont have call waiting feature.
I found where the setting is but its greyed out so i cant check it.
Do i need to call att and change some setting?
not good. have you tried turning off, then on your phone, when NOT charging, to do a soft reboot?
an old pc rule is when in doubt, turn off.
let us know if that worked. otherwise, at&t can do a push update OTA for you to fix it. just make sure to get into the technical department..
let us know what fixes it.
