R radders75 Lurker May 28, 2010 #1 Probably really simple, but how do you swap calls over if another call is coming in on the hero? All i end up doing is disconnecting both of them?
P peterc10 Android Enthusiast May 29, 2010 #2 Did you get a CD with a manual with your Hero? The answer is in there. 1. Press the TALK/SEND button to accept the second call and put the first call on hold.2. To switch between callers, tap the person you want to talk to on the screen.3. To end the current call and return to the other call, tapEnd call.
vals4con Newbie Jun 7, 2010 #3 Thanks Peter! I will try that next time I use call waiting. I just had the hang-up problem this morning. I disconnected my brother.
