Help Caller ringtone
how do I set a song as a caller ringtone
Settings - Sound & display - Notification ringtone
But you need to set some folders on your SD with the appropriate folders, so create one called Media if it doesn't already exist, and within that folder create one called Audio, then the following within that...
Alarms
Music
Notifications
Ringtones
....then copy your tones to the appropriate folders, which will then show up when you try to change them via settings.
thank you! next question, can i set different songs for different people when i recieve a text from them
I used the tone picker app to set an mp3 for my message alert but don't know if you can set different songs for different people. will have to try sometime. Ric
Yeah, why isn't that easier?
I personally want to set up Arlington Alerts with its own ringtone, and that's a bot that posts to SMS via email through a gateway.
