Hello Motorola triumph community, and I have a problem. I use my phone quite a lot for work, and after I switched my PRL I have experienced major call drops for almost every situation.
Sorry was in a rush to get this up heres some more info,
I had been using whyzor's old rom with no problems then I flashed g60madman's 3g fix rom then came the call drops. So I switched to the starship rom then I noticed that it was using g60madman's kernel. So of course came the call drops. So should I just switch back to whyzor's rom or should I upgrade to the mtdev cm7(I really want the camera)? And just btw no hate on g60madman I really like his roms and all the deving he's doing for cm9 and cm10 and a friend uses the same 3g fix rom and is enjoying the rom a lot. I'm just thinking the PRL switch is causing problems.
I would also guess its the prl, not the Roms, since noons else has reported issues with the Roms, and messing with the prl can go either way, u may get a better or worse connection, or it may say u have a connection when u actually dont
And of course, if you do a nandroid backup and it doesn't work out, you can go back. And for what it's worth, I have never had a dropped call. And I have had my phone for over a year. I know it had more to do with the area than anything else.
